MOV setting
helpyou
Automotive
Sep 26, 2011
79
HI
what is the difference in MOV setting configuration between close setting at position limit and torque value.
Thank you
There's likely a logical AND function for the two switches: if either trips, the motor stops.
The torque switch can trip before the actuator shaft reaches its limit, whereas the limit switch is a physical position limit.
