what scottyUK said. I ran a search on emersons website and could not locate that model number. When you say the motor is weak, what exactly is happening? Does it humm, does it move the load slowly? Is it overheating?
Single phase or three phase? Any starting switch?
1725/1140 may be two separate windings. Easy two speed transitions give 2:1 speed ratios. Most other ratios use two windings.
Bill
"Why not the best?"
Jimmy Carter
