See Motor shaft voltages and bearing currents and their reduction in multilevel medium-voltage PWM voltage-source-inverter drive applications, Fei Wang, GE Ind. Syst., Salem, VA; IEEE Transactions on Industry Applications, Sep/Oct 2000, Volume: 36, Issue: 5
Abstract:
This paper presents test results on problems and solutions of motor shaft voltages and bearing currents in medium-voltage pulsewidth modulated (PWM) drive systems. Tests show that multilevel medium-voltage PWM voltage-source inverter drives can cause motor bearing currents, similar to a low-voltage PWM drives, even with one motor bearing insulated. Common-mode voltages generated as a result of PWM switching are observed on motor windings and capacitively coupled to the motor shaft, leading to bearing currents. Potential solutions, including altering common-mode circuitry, changing the grounding scheme, providing common-mode filtering, and grounding the motor shaft, are investigated. Test results on their effectiveness are presented
Also see:
Modeling of motor bearing currents in PWM inverter drives , Shaotang Chen; Lipo, T.A.; Fitzgerald, D.;
Industry Applications Conference, 1995. Thirtieth IAS Annual Meeting, IAS '95., Conference Record of the 1995 IEEE , Volume: 1 , 8-12 Oct. 1995
Effect of PWM inverters on AC motor bearing currents and shaft voltages, Erdman, J.; Kerkman, R.J.; Schlegel, D.; Skibinski, G.; Applied Power Electronics Conference and Exposition, 1995. APEC '95. Conference Proceedings 1995.,Tenth Annual Issue: 0 , 5-9 March 1995, Page(s): 24 -33 vol.1
Source of induction motor bearing currents caused by PWM inverters, Chen, S.; Lipo, T.A.; Fitzgerald, D.; Energy Conversion, IEEE Transactions on , Volume: 11 Issue: 1 , March 1996, Page(s): 25 -32
Bearing currents and their relationship to PWM drives, Busse, D.; Erdman, J.; Kerkman, R.J.; Schlegel, D.; Skibinski, G.; Power Electronics, IEEE Transactions on , Volume: 12 Issue: 2 , March 1997, Page(s): 243 -252
Minimizing electric bearing currents in ASD systems, Link, P.J.; Industry Applications Magazine, IEEE , Volume: 5 Issue: 4 , July-Aug. 1999, Page(s): 55 -66
