Planets
- Nov 21, 2003
- 2
I need to size an electric motor for a traction winch appliction. the motor will be controlled by some kind of VFD and will be operated at either 900 RPM or 1800 RPM. At 900 RPM the required output torque is 14000 lbin and at 1800 RPM the desired motor torque is 7000 lbin. For VFD speed control do I have to size the motor at the MAX torque and Max speed conditions. This would result in a 400HP/1800RPM motor. The actual horsepower requirement is for the two load points is only 200 HP so does this mean the VFD would be sized at 200hp? Any comments are welcome........
