Ideally, you would measure the actual current into the motor.
If your protection CT is upstream of the capacitors, the measured current will be less than the actual current into the motor. You will need to compensate for this somehow, such as by adjusting the motor full load current that is entered into the relay. The relay's overload protection model depends on the measured current being equal to the current into the motor.
