What is the typical setpoint and basis for unbalance protection on an induction motor. Specifically, magnitude differences between the 3 phase currents, negative sequence current and negative sequence voltage.
Background - Induction generator when fully loaded trips off due to current imbalance. The generator is at the end of a long line with a voltage imbalance (within the utility voltage acceptable range). When operating at lower loads - no problem
jpl
jpl
