Hi, I like to join in by asking about power factor and of 3 phase induction motors rated 600V as follows:-
1) pf tends to go down from the same manufacturer for the same horsepower rating as the numbers of poles increase, that's to say, from 2,4,6, 8 ...so on, the pf drops, can some one explain pls,
2) is it true that from the same manufacturer/manufacturing technique & design and same pole numbers, for a given horsepower rating say 200 hp, the pf is lower for a submersible motor (IP 68) direct coupled to submersible sewerage pump compared to the same motor rating of TEFC type from the same manufacturer,
Lastly, appreciate if you all out there can advise how to improve the pf of submerged motor to that of TEFC motor form the same manufacturer, and what's the IP rating possible with TEFC motors.
Cheers
Jyaces1
