supateach2004
Could some one please take a look at the images in the link and help me with my motion environment problems. I am modeling a rear suspension system and have almost finished the final assembly, I only have the shocks to add - see lower image. I want to animate the suspension movement, so I started with just one joint to make it easier, or so I thought! see upper image. I cant get it to work at all, it either does some random movement or I get an error. I have tried going through the intellimotion builder and through the side bar. This is, however the first time I have used motion other than the tutorials.The rod end is made of a sphere with a hole, point aligned inside the rod end outer. The hole in the sphere is axial aligned onto the mounting bolt and offset planer aligned fron the vertical mounting bracket. Could someone guide me though how to get this first joint to move then I can tackle the whole suspension system later.
Thanks in anticipation
Tony
Tony
