I am collaborating on a spreadsheet for the design of monorails for underhung hoists. My colleague is a bit older than I am and has some formulas and information that we cannot verify. He has been working in the industrial sector and this is the way it was always done. I would like to verify these formulas and information so our spreadsheet can be complete and I understand the logic. The problem we are having is with local flange bending, especially for S shapes. AISC does not address local flange bending caused by a point load applied to the flange. AISC only addresses local flange bending for moment connections with a plate welded to the flange. These are my questions:
1. What is the effective length (cantilever length) of a flange in local bending?
We use:
W-shape: bf/2 - k1
S-shape: (bf-tw)/2 - R
R for an S-shape is the radius of the fillet. We can't find the R anywhere except where he had it written down, so we can't verify the values.
2. How do you calculate the effective flange thickness of an S-shape?
We use: tf + (effective flange cantilever - calculated above) x 0.166.
We can't find any references for this equation. It was just always done that way. Does anyone know this equation? What do you use to calcualte the effective flange thickness of an S-shape?
3. How do you determine the effective width of a flange in local bending? We use: 2 x (effective flange cantilever length)
4. Perhaps you use the same equations and information. If so, do you have the references. If you use other methods, do you have referenced for those methods.
We use:
W-shape: bf/2 - k1
