howarts
- Dec 26, 2016
- 31
If a beam or column has certain moments and after you put rebars.. what would happen to the moments? For instance. A beam has certain moment at midpan, when you put the rebar to address the tension (bottom bars).. what would happen to the moments? I assume the beam would no longer deflect for the moments? But there should still be moment.. how much would be the retained moments or actual bending of the beam if there is sufficient tension bars?
