Moment required to prevent (free) falling object from rotating 1
Gios
GR
I am new to the forums so I hope I am posting this in the correct forum.
I will try to explain the problem below:
Link OA can pivot around O without friction.
Mass mO is left to free fall for height h guided by the frictionless rod until it hits spring ks.
Spring ks then deforms and any downward motion stops when it deforms completely (ls).
What would be the required moment Mr to prevent link OA from rotating when the motion stops?
What would be the best srategy to solve this problem?
Thank you!
Obviously, W × L, where W is downward force, and L is distance from the pivot to the center of mass of the rotating link.
In a static situation, W is simply weight of the link.
In a dynamic situation where the mechanism slams down on the spring, your downward force is is weight plus mass × deceleration because inertia will tend to carry your link down further and you need to counteract that tendency with your moment Mr.
Hi Gios
I need to understand more about what you are trying to do with this device so I have the following questions
1/ what position is the link O - A in before the mass Mo falls ?
2/ If it’s in the horizontal position as shown in the sketch, then what holds the arm in this
position when Mo is falling?
3/ Which way does the arm O-A rotate when Mo hits the spring and stops?
Hi Scuka, thank you for replying.
The approach makes sense. The dynamic factor is what I am trying to determine.
I think conservation of energy + conservation of momentum would be a good staring point.
Hi desertfox, thank you for the reply.
To answer the questions:
1/ It is in the horizontal position
2/ There is a moment applied (like Mr) which for the static case it is straightforward. For the dynamic case though we would have to calculate the peak moment which is required to prevent the arm O-A from rotating downwards when stopping.
3/ It would rotate downwards (due to momentum from free fall) and that is what I would like to prevent by calculating the required moment.
Use work and energy during the free fall to find the velocity when m(o) contacts the spring.
Then find the distance and time to compress the spring to determine the resulting moment created by the spring force acting to stop the fall as the spring absorbs the kinetic energy.
Ted
hi Gios
Why not just rigidly pin the arm or fasten it to the mass Mo in the horizontal position? Why is the arm O-A free to rotate in the first place?
is this for work or school ?
desertfox, just a guess but probably wants to know the reaction on the frictionless shaft.
Add an overhanging mass directly opposite to create an equal and opposite moment.
Ted
If there is no rotation allowed then the torsion spring required will be infinitely stiff. What you can calculate is the amount of torque that will be applied if the spring is infinitely stiff - that is, if the arm is completely rigid and the connection is completely rigid and the vertical rod is completely rigid.
The total potential energy will tell what the compression force in the spring will be and that force times the weight on the arm times the length of the arm, less the force to accelerate the mass confined on the rod, will be the torque.
F = (m1+m2)*a; T = m2*L*a.
Looks like a student post to me. No one draws diagrams that nice at work.
I'm wondering if it's a trick question? "when the motion stops" ... so the moment is (when the motion has stopped) ma*g*L
This was based on a discussion we had with colleagues. The situation without the rotating arm is straightforward but the arm makes things a bit more complex.
No one could give a credible answer about calculating the moment.
Hi desertfox.
Well we were discussing about having a rotating arm and fastening it at point O in order to prevent rotation. Some people suggested fastening as much as possible but I would also like to calculate the required moment.
This is interesting, I will try to work on this
Makes sense. I was thinking work- energy theorem until the moment before impact onto the spring and then again until the spring is compressed completely ( downwards v=0).
This would give me the peak force on mO at that moment. Can this also be used for mA though?
No student post, I just haven't used Inkscape for quite a long time and wanted to work with it a bit [smile]
No trick question, by "motion stops" I meant v=0 at max compression of the spring (x=ls). Sorrr if it wasn't clear
The wording around "prevent rotation when the motion stops" is a bit hard to follow but, if you want the link to remain perpendicular to the guide rod throughout the evolution, then it might be less confusing to reframe the problem in terms of a rigid connection and a desire to calculate the peak bending moment at the root of the link. Exactly the same problem, with exactly the same approach to solution already proposed by various other posters - but maybe a useful intermediate step to accepting the validity of the solution.
A.
Gios:
Actually, a real “conservation of energy” would have most of us ignoring these kinds of silly questions/problems, and spending our time working for the guy (or company) who is actually paying us. These kinds of questions should be asked of their T.A. or Prof., so the whole class can benefit from the discussion, or contemplated privately, and near a test stand, and then turned into a Ph.D. thesis.
Gios, draw a free body diagram at the moment of spring contact. Spring force acting at m(o), reaction moment of the rod and m(o), combined weights of both masses. Spring deflection to absorb k.e. will give max. spring force.
Ted
It isn't as simple as that if you ignore friction and damping. As the masses drop at g nothing very interesting happens. When mo strikes the spring at B, the ma continues to accelerate down, but at less than g, and swings on the arm. Assuming the spring/mass system has a higher frequency than the pendulum system, mo rebounds and starts to move up as ma continues to swing, and also starts to move up, perhaps. Then it gets really complicated.
Cheers
Greg Locock
You guys are way overcomplicating.
Imagine that the pivot where A mounts to O does not exist, and they are rigidly fixed together.
OP is asking what the bending moment in the link between O and A will be at the bottom of travel.
In order to know that, OP, you need to know the force the spring will apply, i.e. you need to know the spring rate. This should be obvious; the softer the spring is, the softer the O/A member will land. Less peak force means less peak moment in the member.
-Calculate KE at the moment O and the spring come into contact
-Use the KE of the system to calculate the deflection in the spring at the moment O is stationary
-Use the deflection in the spring to calculate max spring force
-Use the max spring force to calculate the max bending moment in the member
I guess I made it complicated with of course assumptions.[smile]
Total potential energy of link OA = (m0+mA)*g*(h+ls)
Total Kinetic energy of link OA before the velocity becomes zero at point B = (1/2)*(m0+mA)*v2
Total energy stored in spring once link compresses the spring = (1/2)*ks*ls2
Assuming the total potential energy is not converted to spring elastic energy (may be spring is not compressed full or even with full compression some amount of energy is remaining) but remaining energy is converted to rotational energy of link OA, then-
Rotational energy of link OA = Total potential energy of link OA -Spring elastic energy
(I*α*θ) = (m0+mA)*g*(h+ls) - (1/2)*ks*ls2
Total anti-torque required at O to prevent this rotation T=I*α
so Moment/Torque = I*α = [(m0+mA)*g*(h+ls) - (1/2)*ks*ls2]/ θ.
Another assumption- the moment M = mA*g*l is required to be applied at O to maintain the static equilibrium throughout time.
So effectively total moment/torque required to keep link OA horizontal= static moment(mA*g*l) +dynamic moment(I*α)
Where I = mA*l2 = mass moment of inertia of mass mA about O.
I did not read the previous posts in detail and hope my post will not be repeat of the one of them . If the rod OA has hinge connection and can pivot around O without friction and if we are looking for the resisting moment Mr to prevent rod OA from rotating when the motion stops, it is literally means, to locate a RIGID TORSION SPRING at O and look for the moment developing at the torsion spring. That is, literally rigid conn. of the rod to the pt. O.
If we assume frictionless rod and the impact is fully elastic, the approach would be with conservation of energy .Pls look to the following hand calculation .
PS. this is the third attempt to send my post since today morning .. could be internet conn. problem .
