Enhineyero
Hi everyone, I would like to consult regarding this: I have a two span steel beam (WF) with one span as a cantilever. My columns are all I-section. The beam is connected to the column's web. The moment of the cantilever beam is balanced by the adjacent beam (same section with the cantilever), such that the moment taken by the columns is very small.
After designing the req'd fillet weld thickness (assuming that the steel sections are thicker than the weld), what are the other things that would I need to check? is there any? since the load path is almost direct for one beam to another.
I attach some sketch for better understanding.
regards,
regards,
