Moment capacity form bending analysis in Abaqus and direction convention of moment
Tinni1
IE
I am performing a bending analysis in Abaqus for the cold-formed steel U section. The span is 2.4m. Boundary conditions are simply supported. Displacement control load has been applied at 3 intermediate points of the beam.
I have below two questions:
1. I want to obtain the maximum moment capacity of the beam from the FEA analysis. How do I get that?
2. In the history output I have selected the reaction moment RM1, RM2, and RM3 at the loading point location. Is RM1, RM2, and RM3 is moment about the global x, y and z axis respectively?
Any help is appreciated!
Which type of finite elements are you using ? There are several ways to obtain the bending moment, depending on the type of elements.
Yes, 1, 2 and 3 mean X, Y and Z axes in Abaqus, respectively.
For shell elements, you can choose section moment (SM1 - SM3) output. Just be careful when interpreting these values, they are in local directions.
Moments are about axes.
Great, Many thanks!
