Hi guys,
I'm modelling a simple single storey shear wall with load at the floor level. When I have a model with just a planar wall, the pier moment is zero at the top and maximum at the bottom, which is what I expected. However, when I add perpendicular flange walls and analyse with the same load again, there is now a moment at the top of the wall. This is strange to me because I expected the 3D shear wall to still behave as a cantilever. See attached screenshots.
I've set the floor diaphragm slab to membrane so there shouldn't be any flexural restraint provided by the slab.
I'm curious if this is a real phenomenon or a modelling error?
Thank you!
Thank you!
