I am designing a molecular sieve module to lower the moisture content of a solvent from 0.5% down to 0.05%. The solvent is NMP, N-Methyl-2-Pyrollidone, typically used as a paint stripper.
I plan on using nitrogen flow at 200C to 250C for 4 to 8 hours to regenerate the sieve.
NMP has a very low volatility and is typically removed from parts using an acetone rinse.
I am concerned that the NMP may be hard to remove from the molecular sieve beads using only nitrogen.
Should I add a step to rinse the sieve with acetone before I start the nitrogen flow?
