Modifying part in the assembly
cadquestion
Industrial
I'm new. Just a couple basic questions...
I created an assembly with two parts. I used assembly cut to create a hole. I want to now change the diameter of the hole. If you make the cutting tool part the work part and change the diam all works well and the assembly rebuilds correct. If you instead close the assembly, open the tool part separately and modify the diam, save, then open the assembly again it has not rebuilt the part nor does refresh rebuild the part.
Should you only be modifying assembly parts inside the assembly via 'make work part' or is there a workflow I am missing.
thanks.
Are you fully loading the Assembly?
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Are you on Teamcenter ? The settings on there can affect this too.
Jerry J.
UGV5-NX1884
It might depend on your company setup of NX.
It is not uncommon that the administrators on NX set it such that you need to go "Menu- Tools- Update- Update model"
- because the "Menu-tools-update- interpart Update- delay links" is set.
This is because , if you have complex structures and "n" links depending on other parts, you want "to be in charge" when NX updates all these links.
Is this is "not set" NX will update everything when loading and you might loose the overview of what updated and what did not.
Tomas
You need to force an update of the views on your drawing.
When the menu pops up be sure to select all the views in the list.
The views can be set to update automatically, but usually it is turned off.
Jerry J.
UGV5-NX1884
Jerry Toost John,
The delay links is set. I understand it now. Thanks for the help.
