gcoopermax
I typically represent perforated sheet using a solid sheet with equivalent elasticity and Poisson's ratio which can either be obtained from IPA handbook or from a simple FEA on a periodic section of perforated plate. However often there are times where the open area of the perforated sheet is so high that equivalent Poisson's ratio ends up being more than 0.5, which is unphysical and not allowed by the FEA software I use. How do I approach this? One approach could be to "adjust" the elasticity and thickness keeping Poisson's ratio to under 0.5 so as to obtain same strain and stress in a periodic model and then use these values in the FEA simulation. However I am trying to understand how I go about doing this.
