Modelling of Rivets, Bolts and Screws in ABAQUS
newbie12345
Automotive
Jul 27, 2010
4
Hallo Everyone,
I need some help in defining rivets, screws and bolts in ABAQUS.
I am trying to do a crash simulation. Some parts of my car are joined by rivets, screws and bolts. As of now, I have used MPCs for all.
I think this makes the model bit stiffer than it actually is and hence I believe this is not a good FE modeling practice.
My question is, is it right to model screws, bolts and rivets in this way?
Can anyone tell me, how I can model rivet, bolt and Screws in an FE Model using ABAQUS.
Thanks a lot in advance!!!
There ia a feature för modelling screws and bolts in solid with pretension. in CAE: Load > bolt load
Hallo Portliner,
Thanks a lot for the reply. But i believe i cant use it. I am using ABAQUS/Explicit and bolt loads are for ABAQUS/CAE.
Does anyone else have a suggestion?
P.S: I am new in the field of CAE.
Look into this chapter of Abaqus Example Problems Manual:
- 1.2.3 Buckling of a column with spot welds in Abaqus Example Problems Manual
They use fasteners.
Thanks TomaszK.....
I havent tried it out yet...Will let u know the results.....
