Hi all
In NX4....does anyone know if its possible to 'get hold' of the change 'points' at the %Arc Length's originally used to define a variable edge blend?...the aim being to be able to detail dimension to these change points.
At the moment the only way I can see is to create essentially duplicate points on extracted edges before the blend is done and create expressions so the model points 'coincide' with the 'green cube' %Arc Length change points in the Blend operation....any better ideas would be more than welcome! :-D
Adeo
Senior Designer
Aero/Industrial Gas Turbines, Aerostructures, F1, Catia V5 & NX4
Adeo
Senior Designer
