Modelling Bolted joint
swapnil1511
Hello all,
I am new user of Abaqus CAE and im trying to analyse an automotive differential casing mounted on a flange.
I needed advice on how do go about defining the bolting of dif case to flange as I only have the holes on both parts and not the actual bolt model.
Is using a kinematic coupling appropriate or should I use Tie constraint.
Currently I am selecting the nodes on circumference of adjacent hole and tieing them together. but not sure if its right or not.
It is kind of urrnt as I am on a deadline.
Thanks a
Two couplings and a connector or beam in between element is a common method to model simplified bolts.
