Modelling Adhesive
GB
Can adhesive be modelled when only the Tensile and shear strength is known? I am wondering whether you could create a material in 3d and model the adhesive as a 3mm slab under the structure in question, ready for analysis
Tom
It is possible to model an adhesive, but the properties are usually non-linear. With the information you have, you could estimate some linear properties, but I suspect your results would not be very good if the failure location is expected to be in the adhesive. If you are trying to model an adhesive failure, I would say you can't do it accurately with the properties that you have.
Garland E. Borowski, PE
Star Aviation
Modeling of adhesives is discussed in Ahmad's Handbook of Optomechanical Engineering in the chapter by V Genberg. Usual application is in thin layers bonding parts for low stress.
There is a FEMCI article on the modelling of adhesives.
