Thanks to all of you who helped me with my problem on my last post. I got rid of the "Confirmation" message which previously deleted the load, by using the FACE/SURFACE tool to select the exact contact regions. However it stills appears when I constrain the stent... but the simulation runs now anyway.
I am still having great difficulty creating a mesh fine enough to study the contact area in question (inside curved face of cylinder in contact with metal struts of stent)
. I thought I had a breakthrough earlier today when I was messing around with the model in Mechanica FEM mode. When I held the max element size to .1mm on the curved surface, it created a "beautiful" mesh - exactly what i have been dreaming about for the past fews months...<?:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /> </v:stroke></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:ulas></v
ath><?:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" /><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shape></v:stroke></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:ulas></v
ath><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shape></v:stroke></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:ulas></v
But the dream sooon faded when I realised, from looking through this forum, that the meshing is not interchangeable between FEM mode and Native because one uses h-elements and the other uses p-elements.
I have tried creating Volume regions (Local Mesh Refinement with SPA is no good). This has helped to some degree but I read in another post that
"the element edges must have a length less than half of the length of the contact line (or smaller)" - and my contact area is tiny (around 0.01mm) so I'm not sure if Volume regions will help me.
My question is:
Are such small elements really necessary if all I want to get is the Maximum Normal Contact Force on the cylinder due to a radial force from the metal stent and a good representation plot of the stress distribution?
Also any suggestions for achieving small elements efficiently on this curved surface (i.e. pattern??) would be greatly appriciated!
I have upload the latest model (suppressed items and converted for commercial access) here with some volume regions set up.
2005-09-30_150134_Zip_con_5A2.ZIP
At this stage I'm not sure if Mechanica can do the analysis for me and think I might have to go to another package... I hope I'm wrong...
