Ben2
- Feb 11, 2004
- 3
I am attempting to model a suspended floor slab with edge supportes provided by walls, and also supported at mid spans with beams running on each direction. With out the beams the floor slab can be analyzed as the plate structure and I am facing no problem with that. FE software I am using is GTstrudl which can do the required FE analysis in no time. My focus of investigation is to find out how much of the deflections of the slab is controlled(reduced)because of introducing the beam elements.
While my focus is on deflections, I am also intrested looking into bending resultants for the plate(slab) and shear and bending of the beam elements.
Any hint as to how I should model it is appreciated.
