Hello. I am rather new to ABAQUS FEM and would be very grateful for some input on my model and study design.
My overall goal is to model how the tip of a needle interacts in human tissue. Specifically, I am interested in looking at the stress, strain and strain rate for small needle displacements inside of tissue. To model this interaction, I have created a 3D bevel-tipped needle and a block of tissue with the needle profile removed from the tissue, in Autodesk Inventor. I then import the CAD files into ABAQUS.
In my study, I have the needle inserted into the tissue and in contact with the tissue at the start of the simulation. I then want to add a displacement boundary condition in the 2nd step (after initial step) to displace the back of the needle 0.5 mm into tissue to observe the stress, strain, and strain rate.
However, I am having several issues:
1. Mesh. As you can see in the images below, the needle has fillets around the beveled edges so that it does not "cut" the tissue. Creating a mesh for the needle (and for the negative profile of the needle in tissue), seems to be very difficult. I have tried partitioning the needle, but with no luck. Thus, I have reverted to automatic meshing with a bottom-up scheme and tet elements. I've read that this can be inaccurate for results, is this true? Needle image:
2. Contact. I can specify contact between the flat beveled face and the cylindrical shaft of the needle with their corresponding faces in the tissue block. However, I am having trouble specifying contact between the fillet of the needle edge and the fillets produced in the tissue edges. Since there is friction between the needle and tissue, I feel like I need to establish this contact. When I try to specify contact, I get some sort of error that the bevel face and the fillets overlap, and something about a "tie"? (Sorry, can't remember off the top of my head). Here is the initial state of contact between the needle and tissue:
3. Insertion. When I displace the needle 0.5 mm into the tissue, I am finding that the needle actually moves straight through the tissue elements, as shown below! I am wondering why this is happening, is the tissue too soft (E: 7kPa) relative to the needle (E: 50 GPa)? I can't understand why the needle should go straight through the tissue elements.
Middle cut view of the needle in the tissue at the start of simulation:
Middle cut view of the needle in the tissue at the end of simulation with a 0.5mm displacement. Notice how the needle tip actually penetrates the tissue elements:
Thank you very much for your time!
