Modeling O.D.Cam Profile, HELP
  • Thread starter Thread starter JONGPC
  • Start date Start date
J
JONGPC
Guest
I need help modeling a O.D. Cam Profile on a cylinder.
Think of an extruded cut (Keyway) normal to the axis of a shaft, but the extrude wraps around the shaft
instead of in a straight line.
Using CREO 3.
Thanks in advance!
Sounds like you may want to create the cutout volume in surfacing, then solidify
see the attached crude model using evalgraph (you will need to resume all features), is this what you're looking for?
regards
