Hello all. I have a question that I'm sure sounds very easy to many of you. Advice will be greatly appreciated.
Our team would like to modal test a 3,600 lb (6 ft x 8 ft, approximately) piece of masonry wall (orthotropic) and hopefully determine the flexural stiffness in both directions. We have already sawcut the wall and have it laying on the floor in the lab.
Our idea is to suspend the wall from its 4 corners using our overhead crane, with the idea of creating a condition that's as unrestrained as possible. The crane cables are probably about 3/8 in. diameter and are about 20 ft long. The testing program would be a simple quarter-point modal sweep with impulse hammer strikes at the middle of the wall. From that, we can plot the mode shapes for the different frequencies and hopefully solve for the stiffnesses.
I remember in experimental modal analysis class, we modal tested a small aluminum beam in the free condition by sitting it on soft foam. I also remember the teacher talking about suspending specimens using wire (small EA and large L) to create an unrestrained condition.
Would it be better to suspend the wall vertically from only two corners? Is there a better way to approach this problem than what we're planning so far? We do not have a small shaker, BTW.
Thanks in advance.
100,000e
Thanks in advance.
100,000e
