mm/s vibration 2
Altenergy620
I am monitoring vibration on a centrifuge and would like to know what mm/s of vibration means
Vibration can be measured in terms of displacement, velocity and acceleration of the object.
What you are measuring is the velocity of the object/structure/whatever (due to the applied forces) in millimeters per second.
Aercoustics.com
It could be in rms, peak, to peak, or zero to peak, or absolute.
It could be time averaged.
It will be frequency limited.
Cheers
Greg Locock
GregLocock-
Are you British?
Tunalover
perhaps because you said "zero to peak" as opposed to "zed to peak"
Aercoustics.com
