HgTX -
I think you bring up and interesting point for discussion. Assuming that the distribution, not the magnitude of the CONSTRUCTION loads was a factor, if not THE factor, wouldnt this still put some liability on the contractor? As a designer, of buildings or bridges, we typically do not know the means and methods of construction, and as such, place limits on what can be done, at least on new projects. I would think that the contractor should have some culpability in this, given that the "undersized" gussets showed no signs of distress under full traffic loads. Dont get me wrong, I think the desingers should have checked these gussets as well, but it appears that no signs of distress were noted on these gussets during inspections.
