A skirt or a saddle is a structural item.
Thickness should be checked as follows:
Skirt bending stress=
[Weight/Area] +/- [Overturning Moment/ Z]
Thus the [ +/-] means 2 checks have to be performed, one on each side of the skirt, for at least these cases:
Check for wind.
Check for seismic.
Check for empty vessel.
Check for vessel operating).
Check for vessel under hydrotest (in which case , the
wind is lower).
Notations:
Overturning moment = due to wind and due to seismic.
Both not acting concurently.
Allowable to be used are:
S_hot from Div. II , for the tensile case
B for compressive stress
Area= 3.14* (R_av) * t = skirt area
Z = 3.14* t* (R_av)^3 = Skirt modulus of inertia
with:
t= (Skirt thickness) - (Skirt tolerance on thickness plate)
R_av = skirt average radius.
Make sure that there enough material compensation and that skirt access holes are fully compensated.
Note also that skirt design temperature is < then vessel design temperature.This means that S and B and the Young modulus (used for calculation of deflection) of the skirt are a bit higher than the ones used for the vessel.
It happened, that for tall columns and in order to avoid vortex, that the column own frequency has to be improved (e.g. increased), in this case a THICKER skirt than the one given above is necessary.
