Dear readers,
I looked at the FAQ's and the historical discussions, as well as in some text books about heat exchangers, but I couldn't find a substantiated answer to my question. My question is the following:
I want to rate an existing heat exchanger for a somewhat different application. I have no dedicated software for this at my disposal. I use the e-NTU method for this.
"What is the minimum pitch temperature that should be applied for a heat exchanger and on what grounds is the limitation of this minimum based?"
One textbook recommends 5 deg C. I would like to know though what the grounds are for this limitation? I mean a guide line in itself is no reason for a limitation.
I hope someone in this realm of heat transfer experts is able to lift a little corner of the veil.
Thanking you in advance for your attention and your effort I remain.
With best regards,
Karel Postulart
Karel Postulart, The Netherlands
Nuon Power Generation
With best regards,
Karel Postulart
