more22
Chemical
- May 2, 2005
- 6
Colleagues,
I have a question regarding minimum flow required to lift a check valve in nitrogen gas service. I am using a rotameter with a needle valve to set a low flowrate (1 SCFH) to sweep a seal chamber at a pump seal. Due to the risk of backflow into the nitrogen header, we have to install a check valve downstram of the rotameter. Can 1 SCFH of nitrogen in a 3/4" line be enough to lift a check valve? Are there any guidelines I could follow?
I would really appreciate your input,
more22
more22
