Apr 22, 2008 #1 angel14 Petroleum Joined Oct 24, 2007 Messages 5 Location CA Hi, Which is the minimum distance to respect according B31.3 between two butt welds ? The piping is in carbon steel 3/8'' thickness. Can we overlap two welds or there is a minimum distance to respect between each weld? Thank you
Apr 22, 2008 #2 metengr Materials Joined Oct 2, 2003 Messages 15,478 Location US angel14; The minimum distance should be such that NDT of each butt weld can be performed with no interference, and the separation distance should be far enough apart to avoid overlapping weld heat affected zones. Upvote 0 Downvote
Apr 29, 2008 #3 11echo Petroleum Joined Jun 4, 2002 Messages 444 Location US I worked at a major engineering company and we always used a "rule of thumb" of 3" minimum distance between welds. Upvote 0 Downvote
Apr 30, 2008 #4 DSB123 Mechanical Joined May 16, 2002 Messages 1,288 Location GB From my recollection BS2633 calls for 40mm between the edges of the welds as a minimum. Obviously dependant upon the pipe thickness also. Upvote 0 Downvote
Apr 30, 2008 #5 europipe Chemical Joined May 14, 2007 Messages 710 Location NL I've learned as a rule of thumb: 50mm(2") or 7x wallthk. whatever is greatest. Upvote 0 Downvote
Apr 30, 2008 #6 KevinNZ Mechanical Joined Jun 12, 2003 Messages 871 Location NZ This question has been asked many times in this forum. From the replies I surmise No piping code defines a minim separation distance (expect maybe AS4041 but I can not find it in the code) Rules of thumb and company specification range from 2t to 2d. Best reason for separation is to not have a stress riser in the gap between HAZs. The change in hardness in HAZ causes the stress riser. Upvote 0 Downvote
