I work in a 2x150MW Coal fired utility located in Colombia, South America. We will change the reheater tubes in next October so I've been selected by the company to inspect the tubes and their Mill Test Reports in factory prior to shipment. The factories are located in Houston and Detroit. What do I need to know prior to the inspection? Are there special things to check during visit? I'm a mechanical engineering and I'm asking this because this is the first time I do this, even when I have some ideas about things to check during inspection, I don't want to pass by any important check prior to shipment, and our company want to be sure about the correct fabrication and quality of the tubes bought.
The tubes are 1.750”, 2.000”, 2.2500, 2.500” diameter; and 0.135”, 0.150”. 0.180” thickness, in the following materials:
SA-209T1
SA-213T11
SA-213T12
SA-213T22
SA-213TP304H
SA-213TP347H
Thanks for your help!
Javier Guevara E.
Projects, Mechanical Engineer
TERMOGUAJIRA - GECELCA S.A. E.S.P.
SA-209T1
SA-213T11
SA-213T12
SA-213T22
SA-213TP304H
SA-213TP347H
Javier Guevara E.
