I am designing/building a small open wheel hill climb car (bitumen track) with a 1 litre motor cycle engine behind the driver. The driver volume will be a CF tub and the engine volume will be a space frame.
I built one in ’68 from ¾” 1/16” wall mild steel and it is still very successful today with the new owner.
The issues I need to consider are :-
1020 and 4130 have the same E so there is no stiffness advantage when using the same sizes.
If I use 4130 and can successfully normalize the joint area after welding to the same as the rest of the frame the whole yield strength is about 63,300 psi.
If I use 1020 the cold worked yield strength of 55,100 psi remains away from the welds, but could drop to 29,700 psi at the welds for annealed (assuming cold forming strength is destroyed by welding) mild steel.
If this reasoning is correct the frame made of 4130 will survive a light crash better than mild steel with same sizes.
My question relates to the choice of mild steel of 4130 from the space frame.
It is too large to be put in a furnace and would distort if quenched in water (along with any holding jig), and would need tempering even if all the previous was possible.
I would be very happy if I could end up with a minimally distorted, fully normalized 4130 frame.
My realistic choices are Tig welded mild steel or Tig welded 4130 or nickel bronze brazed 4130.
Mild steel option.
Q1
Cold drawn is a lot stronger than annealed but will the Tig welding heat reduce the strength gained from the cold drawing ?
Q2
I am assuming no pre of post heating in Q1, but is this necessary ?
4130 option.
Q3
If I oxy torch heated an as purchased “normalized” 12 length of ¾” dia 1/16” wall tube in the middle 4” to the ideal normalizing temp and air cooled it in still air, would the whole length of tube be normalized as purchased ?
Or would there be HAZ areas near the end of my heating zone ?
Q4
At a typical joint there is a long horizontal tube, mid way along a vertical tube butted to it, a horizontal tube butted to it, and 2 horizontal diagonals plus one vertical diagonal all fitted to it.
Q4a (with 4130 filler rod for consistency throughout)
If I sequentially weld all these joints, which increases the mass per unit surface area, and then attempt to normalize it with an oxy torch, will the whole joint and the rest of the frame be normalized ?
Will there be any HAZ areas ?
Will the generally denser volume be softer ?
Q4b (with ER-70 S2 or ER-80 S2 filler rod for realistic joint ductility)
Will there be any HAZ issues ?
Q5
I read this article recently about cracks opening and filling with brazing material.
"Always avoid brazing 4130 steel. The reason to not braze chromemoly is that this steel has a definite grain structure that actually opens up at medium red brazing temperatures. When brazing alloy is melted onto the steel surface, it flows easily into the many small cracks and crevices in the chromemoly steel. Then, as the braze joint cools, the brass will not compress and it forces major cracks to form in the 4130 steel. Often, a brazed 4130 steel part will crack completely in two before your eyes as it cools."
Performance Welding, Richard Finch, c. 1997, pg. 130.
I have seen mild steel tubes crack on cooling after overheating and burning the bronze accidentally.
Is this a similar ?
Cheers
John
Mild steel option.
Q1
Q2
4130 option.
Q3
Q4
Q5
Is this a similar ?
Cheers
John
