MIL-L-23699 OR MIL-L-7808 hydraulic oil
Aug 30, 2012
205
What is the different between MIL-L-23699 vs MIL-L-7808 hydraulic oil ?
What are the example brands for each ?
Why a mixture of hydraulic oil may cause damage to the actuator ?
Viscosity is the primary difference.
What type of damage did the actuator experience and could this damage be caused by incorrect viscosity?
I second Tugboat on the viscosity. Secondarily, you can compare the additive packages and what functionality they are designed to provide, and if those might be related to your failure mode.
