Midsurface w/ Pro/E
Stringmaker
513
Is there any way to take the mid-surface of a protrusion within Pro/E? I have a sheet metal part which I need to export into an FEA program and the midsurface of this part is required to mesh with shell elements. Any help would be appreciated. I haven't been successful finding this in the documentation.
Thanks in advance,
-Brian
If you have ProMesh, you can grab the midsurfaces from your part.
-Hora
Sumpin you might want to try...
_ Create a surface subset shrinkwrap. Low resolution is usually
good. You don't want the material edge surfs.
_ Create a seed & boundary copy of one face set (driving or offset).
_ Offset the copy and export.
