Hi there. i am new to Nastran, and i am importing large assemblies from Pro/E, using iges format (the parasolid woudl not import), and i have been successful creating meshes, applying contact surfs, etc. i would like to be working in mm\N\s\Kg (metric). i am using 72e9 for E of AL7005. my stress result look somewhat as expected, though my displacements are way too small, in the 1e-6 range. i understnad that Nastran does not understand units, but can someone point me in the direction of getting my disp's as expected. So i'm assuming that it is a scaling issue, but where do i change it - is it Solid geometry scale factor, in the prefs menu?
oh yeah, i made a 100unit(mm?) long bar, with the same mat prop as above, and applied a 1000N force to the end of the bar, and my disps were still 1e-5mm.
thanks for your help.
