Membrane simulation 1
soundchaser
Chemical
CL
Is there any simulation software with membrane (gas upgrading) modules? I tried with superpro designer but works only with liquids, and I need to try different process configurations.
thnx
It depends on what you want. Do you have a mathematical model to solve the problem? If you do, I would use aspen custom modeler, or if the mathematical model is no very complex, you could use polymath.
I've use aspen custom modeler and it worked perfectly well.
Hope I helped
