Mechanical Routing - add curves
jerry1423
3,428
Is there a way to add curves to a mechanical routing path similar to the way existing curves can be added to a sketch ?
Jerry J.
UGV5-NX1899
Yes, there is an option to convert existing curves to be routing path.
( i do not remember the exact name of the command , but it is there.)
Tomas
The more you know about a subject, the more you know how little you know about that subject.
Hi Tomas, Hi Jerry,
Thank you for your information.
I just want to solve existing problem, when design people get the stp data from misumi standard, they have nothing to do with the information in the solid body of stp as output of inquiry.
Maryadi
