A
antran7
Guest
For the life of me, I can't get Mechanica to run on all 4
processors (or maybe it is, but doesn't look like it).
I'm running a fairly long FEA, and my CPU usage stays at
25% (can you tell I've got 4 processors?)
When Mechanica starts the run, here are it's outputted
run settings:
Parallel Processing Status
Parallel task limit for current run:&n bsp;4
Parallel task limit for current platform:64
Number of processors detected automatically:4
But every run has the Elapsed Time nearly equal to the
CPU Time.
I've got these settings in my config.pro:
sim_run_num_threads all
sim_run_tmp_dir D:\Working\mechanica
And I tried this setting:
MECH_NUM_THREADS = 4
but it wasn't recognized
I've looked at my resource monitor, and the CPU, Disk,
Network, and Memory are not maxed out.
Any ideas what the bottleneck could be?
An
run settings:
CPU Time.
An
