S
scottydog
Guest
I am trying to output the rotataion of a bearing outer race as it is loaded in an assembly in a housing. To get the rotation (about Z) I've tried putting a shell element on the surface of the bearing (can't get rotations from solids), which works with the bearing modelled on its own. However when I put the bearing into the assembly, ProE wont mesh the model with the shell element of the bearing in contact with the housing. Anyone got any solutions of either another way to output rotation or a solution to the above problem
