Measuring with telecentric lenses
greif1
Industrial
If I measure a flat object using a lens, projecting onto a flat CCD, is there any value to using a telecentric lens? Or will a high quality enlarging lens, etc. do just as well?
I think that as long as your object and CCD are not tilted with respect to the lens a high quality non-telecentric lens will work just as well.
The main advantage of a telecentric lens:
> Object size is nearly constant for changes in object distance -- If you are making measurements, this might be a big issue. You can compensate by always having measurement reference in the image, but that might not always be possible.
> Depth of focus is larger, so refocusing for object distance changing is minimized
TTFN
FAQ731-376
