Thanks for your time. I have a harness routed from a PD Box down to the chassis framerail and all the way to the rear of a truck. I want to measure the length of that harness from the PD Box terminal to any given point half way through the chassis usig non intrussive method. The harness is protected with convoluted tubing and it contains about seven wires. I thought about using a device that would send a signal, or current through one of the harness' gauge 8 wire from the terminal at the PD Box and with a non-intrussive probe to register the signal at the desired location approx. 2 400 - 2,600mm and calculate an accurate length across a sample of 50 trucks.
This measuring system will be accurate enough to pass an MSA.
I will appreciate sharing your ideas and sugestions on how to do it?
Thank you
EA
Thank you
EA
