Continuous Line - Or not ??
Ah I was intersecting the part with a plane I had created after I had extracted the surfaces and was then splitting the intersection line with points (that were on the hole centres), but then used your idea by creating a line pt-pt and using the surface as the support, but as I have extracted several surfaces there are changes in section and even though I have joined the extracted surfaces together (surfaces now in a Geometrical Set I created) I still have issues when I create a line using two points due to different areas of this joined surface being created from different surfaces and the line looks continuous but when you click on it it actually only shows that part of the line until it meets the next change in section - if you can understand that ?? - Bizarre what am i doing wrong ??
I have another annoying query, if some holes are on a change in section so when you click them the were effectively two half a holes (I know you can't get half a hole but just to explain), so when in GSD and you create point using circle / sphere centre it fails when you select the hole edge as it sees it as two holes - Any advise ??
Just a note on measuring along a surface - I was measuring the length along the curve using the measure item icon (4th from left - the calipers) and I appreciate there isn't a measure along surface, as such, button I just wanted to differential between that and measuring the shortest distance as this will not be along the curved surface
Many thanks for anymore advise
