Apr 7, 2011 #1 petersi Automotive Joined Feb 3, 2011 Messages 88 Location HK I have some gears on hand, I want to check what module on the gear. How do I check? I think they are .5 or .6 module but I'm not sure. Is there a tool for checking gear module? thanks
Apr 7, 2011 #2 dinjin Mechanical Joined Jun 15, 2008 Messages 336 Pitch Diameter equals module times the number of teeth. This assumes no profile shift otherwise you are measuring as cut pitch diameter. Upvote 0 Downvote
Apr 8, 2011 #3 Occupant Mechanical Joined Dec 8, 2006 Messages 355 Location US Or M = OD/(Z+2) if nothing else is going on. Upvote 0 Downvote
Apr 8, 2011 #4 gearguru Automotive Joined Aug 29, 2001 Messages 513 Location US Module is a metric unit. The formulas given by dinjin and Occupant are only valid if you measure the OD or pitch dia in mm. Upvote 0 Downvote
Apr 8, 2011 Thread starter #5 petersi Automotive Joined Feb 3, 2011 Messages 88 Location HK I see thanks so much. Sorry, I'm a grasshopper. I want to know how to measure the Pitch Diameter? It is too small. Upvote 0 Downvote
Apr 9, 2011 #6 juergenwt Mechanical Joined Sep 17, 2008 Messages 216 Location US Open your NHB. Since you have the O.D. and the number of teeth - you can find a formula to figure out everything else. Upvote 0 Downvote
