Measure diameter??
  • Thread starter Thread starter barnam
  • Start date Start date
B
barnam
Guest
How come you can't measure a diameter (or radius) of an edge? For example, pretend this was an imported part (like an igs) and you needed to know what the radius of those fillets were, how would you do it?
It seems like such a simple thing...
View attachment 4379BM
Edited by: barnam
Hi barnam
Cut it in half along the symmetry plane, then you should be able to, if it is not a conic.
Sip
iF YOU CANT MEASURE BY SIMPLE MEASURE
THEN GO TO ANALYSIS-MEASURE- RADIUS
U'LL GET THE REQURED DIM.
A quick and dirty method that could get you pretty close would be to add a surf-surf round between your two cylinders and adjust the R until the the preview geomety does not show. Then just cancel out of the feature.
go to analysis> geometry> Radius select the round surface
Edited by: kirancitd
You need to do a curve analysis to measure edge curvature. In WF3 go to Analysis -> Geometry -> Curvature. Under the 'Geometry' tab you can change the Type from 'Curvature' to 'Radius'. WF2 is similar.
It shouldn't be that hard, but there you go.
Edited by: dgs
Make sections where ever u want to measure
then create curves by using " Use Xsec "
now go to sketcher, create curves taking support from X sec curves ( u can get the dimensions in thesketcher)
I think, it may help u
Venu
Edited by: venu2citd
