Hello all,
When i consider fixed Tubesheet (SA 516 70(Normalized)- Curve D) welded with pipe (SA 53-B) (Curve B), for MDMT calculation, governing thickness is based on tubesheet Nominal thickness /4, while MDMT calculation is based on pipe (Curve-B). It's flat tubesheet directly welded to the pipe with fillet and groove joint.
Can anyone explain me code reference for above calculation ?
