Hello all,
A 100 kW DC motor has been moved from its original place (anchored to the floor) on board a centrifuge which now is mounted on air springs and vibrates.
The motor runs at 1000 rpm the transmission lowers the load speed to 330 RPM. RMS vibration velocity is 1.4 in/s. The motor is not the cause of the vibration, rather it suffers it, the source is the machine itself.
Is this too much? Using the vibration severity chart of course it qualifies for "stop it right now", but that chart takes into account that the motor is the cause of the vibration. This is a perfectly balanced motor riding on a rough machine... and it has been working well for the past 3 weeks (about 30 total hours of operation, each batch lasts 5 minutes and the process 24 batches a day).
I attached a photo of the motor and part of the machine.
Thanks!
Thanks!
