Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
That was a little off. Should have been:electricpete said:Typically we try to match angles closely, erring slightly on the side of generator angle lagging supply angle to avoid reverse powering the generator.
corrected said:Typically we try to match angles closely. Also we try to match frequencies, erring slightly on the side of generator frequency higher than supply frequency to avoid reverse powering the generator.
