optiengg
- Jan 8, 2007
- 6
The thickness of two way slab is dependent on its unsupported
perimeter, so larger the perimeter, greater will be its thickness.
For a 20 x 24 panel , it is about 6.5", but goes upto 9" for 25 x 35 panel.
When should we consider subdividing slab panel (hence reducing slab thickness), by using simply supporting beams but at the cost of loading main grid beams with concentrated loads which may come right at their midspans.
